Hi,
I have started a diy flashlight project with led cree XML-T6.
I have made the body with aluminium,the heating is approximately 70 celcius.You think is pretty high?
The beam concerns me a lot pls tell which is the best way.
I have two options.
The first is to use 20mm 30-Degree Optical Lens for Cree XML T5 / T6 / U2 LED Emitters
And the second with smooth or peel orange reflector.
OR a smooth reflector.
Which is best for you and for what reason?
The other question is about the optical glass lens I have two options again.
The first is
[TABLE="class: TightTable"]
[TR]
[TD]AR Coated Optical Glass Lens18mm*1.5mm / double side multi-layer AR coated
[/TD]
[/TR]
[/TABLE]
Antr the other a simple Optical Glass Lens (5-Pack)
20mm*1.1mm
s
The rest of the flashlight is not ready yet(battery tube),
What is your opinion for the best result?
I have two options.
The first is
[TR]
[/TR]
[/TABLE]
20mm*1.1mm
