Do CR123A leak ???
Timothybil
The great state of Misery (Missouri)
I picked up another G2 last week, and it came yesterday. Not having any extra 16650 cells laying around, I dropped in a couple of CR123A cells I had lying around in my battery box. After I tested my new G2, the thought hit me. Has anyone ever seen a quality CR123A cell leak? I won't be using this light much if at all, and I don't want it to get gooked up by a leaking cell.
xxo
Re: Have you ever seen?
Nope never seen or heard of a CR123 leaking.
I did have a overdischarged Eneloop AAA leak though, just a drop or 2 of rust colored fluid that stained the white disk on top of the battery but didn't seem to do any damage aside form that (the cell still functions with good capacity).
archimedes
CONUS, top left
... title replaced with something informative ...
ChrisGarrett
Miami, Florida
I've used a lot of them in my ADT alarm sensors for 15 years and never had one leak. Even some of the Chinese sourced versions they provided, haven't leaked.
Chris
TheShadowGuy
Leaking, not usually. But they can fail catastrophically.
http://www.candlepowerforums.com/vb/showthread.php?330044-Dangerous-explosion-with-2-CR123A-primary
This next one caused permanent damage and, in my opinion, is required reading for anyone looking to use loose lithium based cells (primary or li-ion). Battery safety is important!
http://www.candlepowerforums.com/vb/showthread.php?340028-Flashlight-Explosion
Long story short, using two or more CR123a batteries in series of differing voltages (or if one battery drains faster, which can happen with cells from different manufacturers, times, or partially used cells), the lower voltage cell can end up being charged. The ultimate result being potential for catastrophic failure, and gases like hydrogen fluoride are released. There are other scenarios in which a battery can fail, and it is important to treat them properly.
https://emergency.cdc.gov/agent/hydrofluoricacid/basics/facts.asp
StarHalo
California Republic
Yeah, the cheap ones have an explosion problem so skip those, avoid the issue in quality cells my mating them by nearest voltage when using more than one. Other than that all they do is slowly let off ether.
