Albinoni
Banned
Picture this, you have say 3 LED torches and as follows:
1. Torch A takes 2xAA
2. Torch B takes 2xAA
3. Torch C also takes 2xAA.
Now all your torches run on Eneloops.
So say after 2 weeks of heavy use all torches batts run flat and you now need to recharge the Eneloops from the three torches.
Once all the Eneloops are fully charged up and ready to be re-used, will you use the batts that were in Torch B into than either Torch A or C, or mix C with A or B with C and A etc, or do you always use the same set of batteries in the same torch no matter what. So say for eg, if you remove the batts from Torch A you will always return those same batts into Torch A etc.
