Does anyone use a Nano or WF-138 to charge 14500's?
Gatsby
Charlotte, NC
I note that AW mentions you can use the 3.7 chargers with a 14500 using wires and an alligator clip. Does anyone do this?
I now have a few lights which are designed to use 3.7v li-ion rechargeables, unfortunately they all take different sizes (Jil JCR2 IT - RCR2; HDS EDC - RCR123; LF5 and hopefully a CAB for the Jil - 14500). The RCR2 and RCR123 cells will get the most use - the LF5 runs pretty well on NiMH and lithium AA cells and the CAB is really for a longer runtime option when needed - so I'm inclined toward a 123 sized charger since the smaller cells will get the most use.
I can see how a wire alligator clipped to the charging terminals of the charger works (taking care to mate + and - properly) but how do you attach them to the battery without the spring loaded bay? Does anyone sell such wires?
Thanks!
LuxLuthor sells magnetic connectors which are suitable for this purpose. The open wire end goes to the charger terminal, and the magnet onto the battery terminal. Red wire for +ve, black for -ve. The strong magnets make a good contact.
To attach the wires to the charger, use a non-conductive spacer, such as a piece of wooden dowel cut to the right length. To be ultra-safe, use some non-flammable material, but fire is not a realistic danger with a small charger like a Nano.
If you want to use a Nano charger for charging a 14500, get the R123-size one, as the 10440 size will be slow.
Test-leads, with crocodile-clamps in both ends:
and small, strong magnets on the battery.
Good for charging even 18650-cells with the Nano, I use the Volt-meter to check the voltage and remove the battery when voltage is 4.20 Volts.
Takes 40 hours though, to recharge an empty 18650 cell!
