Does this light exist?
holygeez03
I recently purchased a Neutral Quark X, thinking it was the exact light I have been hoping for... however, the tint was way too cool. so now I am wondering if there is an alternative.
Criteria:
1) Must be neutral/warm tint!
2) Must be able to swith directly back and forth between two brightness levels (programmable preferred, but must at least remember the last level)
3) Must have a "floody" emiiter, XM-L preferred for beam pattern and brightness.
4) Must run on 1-2 x 18650 (prefferred) or 1-2 x 17670.
5) Prefer brightness over runtime, this will be for the backyard and I can easily swap batteries.
For the record, I own an older Neutral Quark AA^2 and it is close to what I want, except I want brighter and li-ion battery use. I also have a Neutral/warm Neutron 1A that I use with a 14500 and I like it a lot, but want a bit better build quality and larger li-ion battery. As stated above, I thought a Neutral Quark X 123^2 would fit the bill perfectly (with a 17670), but the tint is not neutral/warm enough.
My first thought was to find a Neutral Neutron 2C, but I have read that it is not compatible with 17670?
I also plan to purchase a Zebra SC600w as soon as they exist, but it still won't technically meet my demnd of "switch directly back and forth between two levels".
Let me know if something exists that I don't know about. Thanks.
U could get a warm XML drop-in from Nailbender in 2mode.
Buy a cheap L2P host and yer set.
Under 100$ for everything.
He has tons of tints and emitter choices.
Edit- oh yeah the ano on the latest L2P is really nice.
It is not difficult to switch between levels on a Zebralight. From off, do a double click and you end up in medium. On medium, click once to off and click once again to get to high. Simple. I have no problems mastering the UI in a day.
I may need to look into that route.
I have several Zebralights and very familiar with the interface... But when I'm with my dog at night I constantly switch between high/medium because I don't like shining a super bright light on him and it's preferable to just twist a bezel back and forth.
^Nonsense! If it works for pjandyho, then you need to redefine your criteria.
I noticed you mentioned possibly 2 18650's- what are your length & diameter limits, & how low does the low have to be?
take a look at :
-dereelight cl1-h T xm-l neutral or warm (needs extender and 2*18650 for full power)
and not yet avail. in NW but still to consider :
-thrunite tn12
-zebra sc600
pjandyho's explanation for getting from medium to high involves clicking the light "off" then back "on". I clearly stated that I want to be able to switch back and forth between high and medium.
No real limitations on size... this will sit on a table in the house and be used in the yard when keeping an eye on the dog at night.
take a look at :
-thrunite tn12
-zebra sc600
Thanks for the reply... I will take a look at the dereelight. Neutral/warm is a must, and the SC600w will likely be my next purchase when it is available. If the tn12 becomes available in neutral, I will consider that as well.
