Does USB 2 need special cable?
TOB9595
UNDER GOD
I'm wondering if USB 2 devices need special usb2 cable
AND
if the hubs are special
for the thruput?
or can the usb1 hub and cable transfer the data at the design of usb2
Anyone?
Tom
I'm pretty sure you need hubs which are made for USB2. Cables, I'm not so sure - I see a lot being sold as 'USB2 certified', but don't know that there is really much difference between these and plain old USB cables.
Graham
USB 1.1 cables should work fine, you will need to get a USB 2.0 hub to benefit from the extra speed USB 2.0 offers (a standard USB 1.1 hub will work but will slow the system down to 12Mbps)
USB 1.1 Max Speed = 12Mbps
USB 2.0 Max Speed = 480Mbps
I have used short USB1.1 cables before.
The longer ones don't work so well.
There is a huge frequency change between the two speeds.
Its like going from a ten based network to hundred based, except five times worse. /ubbthreads/images/graemlins/smile.gif
In order to be safe, everything has to operate at usb 2.0 for the speed increase. Motherboard or card>Cable>Hub>Cable>Device
I've always used my old USB 1.1 cables for my laptop and my new Mobo, which is 2.0 compliant... No difference at all...
I get delayed write errors and storage not ready errors when using my old 16' usb 1.1 cables. USB 2 was announced well before its actual market introduction. A lot of usb "1.1" cables really are USB 2.0. Some of mine even say ver 2.0 on the wire. However, I have lots of problem with older, longer cables..
