What other issues could cause the downboy stability problem (not lighting up on 3x123)? I figured the problem would be non-existent on the lastest version boards but I'm having problems with one. As I always do with my McLux builds, I setup the board in the ecan and solder the leads to a test luxeon. I checked it on fresh 3x123 and it lit up fine. So I then potted the ecan/board and went ahead with the build. Now it won't light up correctly on 2xR123s nor on 3x123 as it did before I potted it. On 2x123 it works perfectly. I used 2ton devcon epoxy mixed with alumina oxide powder as I always have with all my builds. Any ideas? Thx
