Driver for 500mA
WarriorOfLight
In the middle of Europe
Hi
I'm looking for a 500mA driver, that is intended to be used with a Nichia NCSU033B UV LED. My particular LED hast the M range (3.6-4.0v Vf). I want to build this parts into a P60 dropin shell. The power supply is one 18650 cell.
The BB Nextgen 500 and the GD Buck/Boost Converter looks both very interesting. I assume only the GD Buck/Boost Converter is a buck / boost converter. Since the Vf of the Nichia is in the volate range a buck - boost driver would be the best.
Is the GD Buck/Boost Converter usable @500mA? What diameter in mm does this drivers have?
Best regards
Thomas
Best regards
Thomas
The GD can be configured at 500mA, and will work great with the Nichia NCSU033B UV LED. The converter board is 0.55", or 14mm in diameter. You can use a contact board in the P60 drop-in, and place the GD inside the shell. The NCSU033B is the best UV LED that I have ever used.
Here are some of the light engines that I built using the Nichia NCSU033B UV LED. They all used either a GD or GDuP converter.
Thanks :) But in the documentation of the website there are two values r1 and r2. Since I do not know what driver IC is used I can not check out the semicuonductor data sheet.
WOL,
Dtailed is correct. R1 and R2 are place holders. To make 500mA, R1 has 0.10 and R2 is blank
