Not sure if this is the correct forum for this question, but I figured you guys would be able to help, or at least point me in the right direction.
I'm thinking of trying to build a bike light and I understand that you need a driver to power the led's, and that the driver delivers a constant current to the led.
What i don't understand is the voltage side of things. Most led's seem to have a voltage of 3.7 volts, but what voltage does the driver output. Does it output the same voltage it has coming in, or does it regulate the voltage to 3.7 volts automatically.
I get that a buck driver lowers voltage, and a boost driver increases voltage, but by how much, does it depend on the driver itself, ect.
This is the only part that seems to confuse me about the DIY route.
Not sure if this helps or not, but I'm thinking of modifying a p7 or mce flashlight and I'm thinking of replacing the stock driver with something better. I was planning on using between 2 to 4 18650 cells wired in parallel, would consider 2s2p if it would benefit in anyway.
and also, am i better using 2 drivers wired in series/parallel to give me a high/low mode?
I know these questions have probably been answered before but I've spent hours looking here and the MTBR.com diy light forum and haven't had much luck finding any answers.
Thanks in advance for the help!
