Hack On Wheels
Hi all,
Just to let you know, this would actually be for a bike light system. I am hoping to make a relatively cost effective system with a spare LED (and optic) that I have, but of course there is no point having it cost effective if it can't still perform... so without further ado, my plan:
-Single R2 (I believe the Vf ranges from 3.5-3.7 depending on current)
-1 ohm and 2 ohm options, to be selected by an On-Off-On toggle switch
-4 x AA NiMH (using a battery holder)
According to my calculations...
If R = 1 then (4.8v- 3.7)/ 1ohm = 1.1A which would be fine for my high setting.
If R = 2 then (4.8v - 3.5v)/ 2 ohm = 0.65A which would work as a bit of a lower setting.
I was planning to use cells with something in the range of 2600mA capacity... high self discharge wouldn't be a big concern as they would be charged frequently. However, I don't know if I need to be concerned about voltage sag or the battery holder knocking down the voltage or anything. Do any of you light/battery wizards have any ideas or suggestions for me?
Also, if any of you guys can tell me how I would wire this up to have a High setting, a Low setting, and an Off using a On-Off-On toggle and two resistors, that would be much appreciated.
Thanks!
Thanks!
