Atomic_Chicken
Greetings!
I plan on doing some "dunk testing" on my waterproof lights, to see which ones really are waterproof and which ones are marketing victims. I plan on using a long shoebox-sized plastic container, filled with about 4" of distilled water (so no residue gets on the flashlights from hard water deposits). I plan on turning the lights on, then placing them in the water for an amount of time, then removing them, drying them, then turning them off.
My question is this: How long should I keep them under water to gain a pretty good confidence in their waterproofness under normal foul-weather conditions with allowance for the occasional drop into a stream or puddle? Less than a minute? Several minutes? Overnight?
What do you all think the test "duration" should be?
Best wishes,
Bawko
Best wishes,
Bawko
