I found many packs of what I thought were Duraloops while shopping locally. White tops, slightly squared-off post, label wrapping around the bottom... looks just like what I've seen in photos on threads in this forum. So I bought a bunch.
With Eneloops having a stated capacity of 2000 mAh, I expected these Duraloops to test at 1900-2000 mAh in my La Crosse BC-9009's "test" mode. However, after running multiple tests, I've found the average capacity to be 2090 mAH (lowest cell was 2020, highest was 2140).
This leads me to question whether these are really Duraloops, because the capacity is more in line with that of Rayovac Hybrids. I have never had a test result in a greater-than-listed capacity before this. This is also the first time I have tested LSD cells though, in case they test differently.
So, what do you think? Duraloops or no?
Thanks!
Thanks!
