I just got
http://dx.com/p/cree-xm-l-t6-600lm-3-mode-white-light-headlamp-bicycle-light-golden-4-x-18650-156263 last night.
First impressions/readings: Batteries were shipped dead. (After 1 hour charging) I read 7.4 volts (two series, two parallel), not 8.4 volt (who writes the manuals?) 1.15 amp high/.25 amp low, 2200 stated millamp hour at 7.4 volt pack (crappy, super low end 18650's apparently) So, in theory (if my meter correct and stated capacity correct), I should get about 8 hours and 20 hours on low and 120 minutes on high, if flat regulation. With a diffuse lux ratio comparison to the Fenix HP11, I get 125 lumens low and 600 lumen on High. 3,700 candela on low, and I think (didn't spend too much time on a crappy runtime setting I will never use) about
14,000 to 15,000 lux at 1 meter (don't recall exactly the number) on High.
Does not look water proof at all. ( I will silicone caulk the switch.) The head band is super small for my head (I will need to splice in more elastic). The hot spot is slightly larger than the HP11, but not significantly. Slightly ringy beam due to a low loss smooth reflector. The switch is always illuminated when head is attached to battery, which has dubious benifit and obvious downside.
In essence, I got a light with about half the efficiency of the fenix hp11 (due to typical guzzling DX driver), but this is overcome with double sized battery pack (which should easily attach to belt). The reports are that the battery charges slow. An investment of another $80-$100 in high end cells (and holders) and $30 4 bay charger, would make this a okay light with 6 hours on high, and 3 work days on low. [Though, with the low efficiency of the linear pwm (pulse width modulated) driver, I don't think it worth the effort. I will wait for the the future Fenix headlamps; and if they keep good drivers, invest more there. ]
So, for $42 and 2 months wait, I got a light that should shine for just under %80 of our typical work day with about %85 of the HP11 brightness. Time will tell how long the compents last. Fenix also has very a good warranty, ulike this light.
