eagletac g25c mark 11
gilson65
Australia
Has anybody had problems fitting keepower 3400.Width ok but length wise seem to be to long tailcap very tight going on.Its ok when using 2x cr123a.Definitly not thread but seems to be connection inside tailcap because only spring loaded at tailcap doesnt give much leaway also have tried a master instruments 3100 (panasonic cell) with the same problem
I have the G25C2 first version and i tried a Keepower 3100 protected Panasonic that was too long.the light is kinda picky on batteries IMO.
What 18650 you using now mine will screw up but very tight.From what i see keepower certainly not the longest protected wonder if eagletac batteries fit ok not much longer?
eagletac g25c mark11
I dont have an 18650 that fits i use now a Eagletac 17670 but i was informed that any Eagletac 18650 would fit (or should :) )
Sent from a mobile telephone
Re: eagletac g25c mark11
ET batteries are generally shorter than others. Even though they also use Panasonic cores as well. Dunno why.
I think it is because the elektronics are maybe shorter/smaller. (if you where talking about protected 18650s)
I find if i undo the head and then screw the tailcap on its not as bad it tends to make a clicking sound i think caused by the black disc in tailcap l might invest in a eagletac battery they say there 68 mm
