secureone
can anyone tell me how to install the gitd switchboot and lanyard on the Eagletac T20C2mkII?
You need either tweezers or really thin needle nose plier. Remove the tailcap and look inside, you will see the two holes in the metal ring called a switch retaining ring. Place the tweezers or needle nose pliers in the holes and turn clockwise to loosen, remove the switch retaining ring. Now pull the switch out and you will see a metal spacer ring pull it out and then the rubber boot. Replace with your GITD boot and then the metal spacer ring (the nubby part on the ring faces down) now put the switch in and the the retaining ring, turn counter clockwise to tighten it down nice and snug and your finished.
The lanyard is meant to be installed on the clip, I don't really like it either I wish it was like the older models instead with a hole in the cigar grip ring.
