bshanahan14rulz
does that really use 5mm LEDs? I have a hard time believing that. But I WOULD like to know what's in them... :whistle:
Only one thing did you post was factual, and that's CFLs get lowered lamp life via off/on.That's simple, a CFL won't ever really last 10,000 hours. I kill those things around my house in about two years, or about 3000 hours. CFL's don't like being turned on and off all the time, which shortens their life.
So really you are looking at $40-60 for CFL cost over the life of an LED bulb. Unless you have a CFL that you are leaving on all the time, then you will get 10,000 hours.
LED bulbs are not bothered by being turned off and on all the time.
They even proved this on Myth Busters.. I'll have to see if I can dig that up...
How do you know how many hours his will last? No one knows that for certain. That's the point. Because no one knows that, none of us can say for certain how much more he'll spend going with CFLs. Wasn't that one of your main points?Um, everything I posted is a fact.
1. CFL's life is shortened by being turned on and off (which we agree)
2. LED's life is not affected (tried and true)
We've been through this before. CFL's are a fine lighting source, but LED's are a better option if they work for your application.
Question.
Why did you buy the short bulb Evolux sh instead of the long bulb Evolux s?
Not critical in a single bulb home application but air conditioner savings in high quantity commercial application might be significant especially in a warm climate like Texas.
I was reluctant to buy the Evolux because of the fan. No guarantee the fan would last 11 years when you consider the fan would draw a lot of air AND DUST into a small space.
What kind of fixtures/lamps will you be using these bulbs in. Having the right LED bulb AND LAMP is critical for maximizing the effective use of LED lighting. The LED bulb must be pointed at where the light is needed.
