MrGman
- Joined
- Feb 6, 2007
- Messages
- 1,777
I need to convert flashlights from white LED to blue for optics inspection related work, at work. We are buying the 3 watt blue LED star type components and need to find something cheap and relatively easy to put them into. Have to do several units.
Something that has the 2 CR123 battery form factor would be preferred. I know the Dorcy 3 watt 3AAA form factor flashlights would work but battery power is on the light side.
We successfully converted a Streamlight 3AA 1 Watt Luxeon light I already had at work. Turns out they only have a 1.5 ohm resistor in series from the switch and battery to the LED chip as the entire circuitry. We added a 1.0 ohm resistor in parallel to change it to a total of 0.6 ohms and put in the 3 watt blue LED star. (No great victory here but it is very useful). But these things are still priced around $37 at the local Fry's and its far more than they are worth. Considering what little is inside. Trying to find something with a half way decent regulator/driver circuit to help maintain power would be a nice plus. Need to make several.
If there is a nice blue LED flashlight out there that I missed other than the Inova X5 in blue (need more power) that is around a 3 watt, something better than 30 lumens real output, please let me know where to find it. Doesn't have to be a 100 plus lumen thrower. Thanks, G
