Also, check out my new Maglite 2 D Monster build kits with FlexModP3! (and others) Awesome!
http://laserpointerforums.com/f64/fs-large-maglite-monster-kits-flexmodp3-side-button-forward-clicky-57278.html
I bought a drop in reflector/heatsink/driver/P7 module from DX and fit it into a 2D Maglite...
I'm using 2 X 5000mAh 32600 Li-Ion batteries for this bad boy.
Here's the P7 module:
DealExtreme: $22.28 SSC P7-C 2800mA LED Module with Copper Base (3.6V~8.4V)
Here's the batteries:
http://www.kaidomain.com/ProductDeta...ProductID=2708
Here's the charger you want for these large batteries:
Ultrafire WF-188 Charger for 14500 / 17500 / 18500 / 18650 / RCR123 3.7 volt Lithium Battery Charger
Details of this easy modification are shown in this 'picture tutorial'...
Switch removal and modification:
The switch needs to be removed. Then cut the center post that holds the stock bulb short.
Then solder on lead wires as shown in the pictures.
Fitting the reflector:
The reflector fits, but it sits a little higher than the stock reflector, so it would leave a gap between the retaining ring/bezel of the host, and the head unless some modification is done...
Battery prep:
Tail cap mod:
I modified the tail cap spring just because I wanted it to fit the 32600 Li-Ion batteries better. The stock spring position was a little too tight. Plus, this tail cap mod will also fit 32650's if you end up getting those...
Final assembly:
That's pretty much it! Then just put it together...
Current Draw:
* 1360mA's - Estimated run time between charges: 3 1/2 hours...
I was expecting twice the current draw, but I'm happy! :)
This P7 gives a much better throw than my two other P7 flashlights, with less current draw! (1360mA's)
Also, it is noticeably brighter than my 2 X 18650 P7 build which is drawing 2.6 Amps.
This has me scratching my head...
I must have gotten a very efficient P7 emitter or something. What ever the case, it's much better for me!
A brighter light, with much longer run time between charges! :D
Hope you like it! I know I do...
Take a look at my XM-L T6 Maglite 'Stubby' (cut down to fit a single 32600) here! It shows a couple of different emitters used actually, but the XM-L T6 emitters have been ordered. Drivers too. So it will be updated soon!
http://www.candlepowerforums.com/vb/...d.php?t=305195
Battery prep:
Tail cap mod:
Final assembly:
Current Draw:
