Easy upgrades for Maglite 6D and 7D?
cudakidd
Howdy all, new to the forum.
I have two of the old Maglites, what kind of upgrades are there that are drop ins? Lens, bulbs, etc? More Lumens available?
Thanks!
:welcome:
I don't see any listings for 7D. Uh see the superbrightleds PR2-1WHP-30V below.
From malkoffdevices. Malkoff is always sold out. Sign up for e-mail notification.
Drop-In Module for 3-6 D-Cell to fit Mag-Lite
Pre-cut Maglite reflector to fit a Maglite with the Malkoff Drop-in installed.
From Battery Junction. Also available from led-replacement
TERRALUX TLE-300M-EX EXTREME FOR 4-6 D CELL MAGLITES 700 LUMENS / 3 LEVELS
TERRALUX TLE-300M-EX-S EXTREME FOR 4-6 D CELL MAGLITES 700 LUMENS / SINGLE LEVEL
TERRALUX TLE-6EX MINISTAR5 LED UPGRADE FOR 4-6 C/D CELL MAGLITES
1 WATT LED FOR USE IN 2-6 CELL C/D MAGLITE® FLASHLIGHTS TLE-1F
From eBay. Note all flood.
Budget Showerhead drop-in for Mag. Fusion 36, now available in warm.
http://www.candlepowerforums.com/vb/showthread.php?277748-Budget-Showerhead-Mag-Drop-in.
superbrightleds has a couple of PR LED bulbs.
PR2-1WHP-30V. Flange base 1 Watt High Power Cree XRE Cool White LED. 1 to 9 Volts DC and 7 to 30 Volts DC. 100 lumen.
I recommend the 7-30V as buck regulators are more efficient and probably brighter.
PR2-3WHP-9V. Flange base 3 Watt High Power Cool White LED. 3.5 to 9 Volts DC operating voltage range, 180 lumen. 110 degree beam pattern
For incandescent upgrades.
Maglite's Xenon bulbs.
http://www.maglite.com/highintensity2_new.asp
R.O.P. Roar of the Pelican
http://www.candlepowerforums.com/vb/showthread.php?140021-Incandescent-Forum-Threads-of-Interest
You need the glass lens and metal reflector. The bulb runs so hot it will melt the stock reflector and lens. You do not need the battery adapter as you already have a 6D.
Popular bulbs current draw; SF & other brands, incl hotwires
http://www.candlepowerforums.com/vb...urrent-draw-SF-amp-other-brands-incl-hotwires
There may be bulbs for your 7D there.
Again you need to upgrade your reflector and lens.
