Hey guys, I'm looking for an AA EDC light with pretty specific criteria. I've searched for months and turned up nothing, so I guess I'll just try my luck here. I need it to be able to put out at least 200 lumens OTF, though I would accept 180-190, with as close to an hour's runtime as possible; be around 17mm in diameter, max 19mm; have a low of 1 lumen or below and at least 4 output settings (e.g. 1, 20, 100, 200); quite floody (preferably XML) with neutral white output; have a clip; durable enough to stand some urban abuse; current regulated. Rather large bonus points for infinitely variable control/programmability and 14500 support, but I don't need them. Throw is unimportant as I intend to use an 18650 in any situation that would require throw.
As far as I'm aware the only 2 AA lights capable of this output are the Zebralight SC51 and Thrunite Neutron 1A, but they're too big. I will be carrying this in my front pocket, and I'm not a big sized guy, so the small diameter is very important to me. Yet, I would like one that can put out enough light to use outdoors. It doesn't need to be for extended periods of time, so even if smaller lights may get hot faster I wouldn't mind. 200 lumens isn't a terrible lot of light anyway. I know 14500 lights can do that but I don't like the runtimes and Li-ions seem to be a terrible hassle. Besides, the only 14500 compatible lights I know of that are capable of a sub-lumen low mode are the jetbeam and sunwayman infinitely variables, but they're thick.
I'm aware of tgwnn's AAA project, and I'll definitely be getting one of those, but a little more battery capacity would really make my day. An AA version of his torpedo could be a year or more away.
If anyone's aware of RCR123 lights that fit this criteria I'm open to suggestions, but it's difficult bearing in mind the diameter limits.
Here's the standard checklist for reference.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
_X_I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
_X_Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
_X_I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_X_I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
_X_Keychain size.
_X_Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
_X_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_X_I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X_I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
_X_I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
_X_I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_X_I want to navigate a dark room or read a map (0-10 lumens).
_X_I want to walk around an unlit rural area (50-150 lumens).
_X_I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
_X_Less than 1 yard/meter (reading, other close work)
_X_Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X_5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
_X_30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
_X_Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
_X_I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
_X_I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
_X_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_X_Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
_X_Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Thank you all in advance for your help :)
____Less than $25.
____Less than $50.
_X_Less than $100.
____Less than $150.
____Less than $300.
3) Format:
_X_Keychain size.
____Holster carry.
____I don’t care.
____I don’t know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don’t know.
_X_I don't care.
____I don’t know.
____I don’t care.
____I don’t know.
____I don’t care.
____I don’t know.
_X_Pocket/belt clip
____Holster
