Billspider
How often do you either change or charge the battery in your EDC,
Merry Christmas to all!
I have a Fenix LD12 which is my EDC.
I had a fully charged Eneloop with a reading of 1994mah 1.45v installed for one week.
Today I removed the battery and charged it on my Maha C9000.
The Eneloop took a charge of 301mah and ended with 1.45v.
The volt reading before charge was 1.31v.
Any thoughts or observations would be appreciated.
if I can't remember the last time I charged them.
Sorry to disagree but dealing with 18650's I rarely rely on my memory about charge/discharge. I relay on my buddy the DMM.
I never check voltages of my li-ions with DMM.. that being said, I try to ensure my EDC (Xeno E03 NW running on a 840mAh 14500) is fully charged up whenever I leave the house.
Actually, none of that is required in my case, as I use hobby charger which displays voltage of cell on it's display.You don't need a DMM, a good voltage meter would be ok. A DMM or voltage meter is necessary if you are using Li-Ions. You need to know what the voltage of the cell is after charging, mostly for your self protection. Also checking the voltage after you light has "run down" is important to to see if a cell has been under discharged, which also can be a dangerous situation. If you do not own a DMM, or other voltage measuring devise, then order, or go down to Harbour Freight and pick one up, the cheapest is about $5.00.
Bill
