EDC Battery idea w/pics
Pydpiper
Brantford/Woodstock
I wanted to have a way to keep a set of batteries with me without taking up extra space and to remain water resistant at the same time.
I Used a piece of schrink tube, made 3 plastic washers for each end of the batteries, insert a cord for neck use or with a keychain or whatever and with great caution heat the tube to a snug fit. Awesome results.
Ok, got it..
To get the cells out just snap it in two.. Completely disposable, even the shoe lace. /ubbthreads/images/graemlins/wink.gif
If those are CR123's, you can strip the label thingy off of it and use a heat shrink tube to suck two of them together to make a single drop in battery.
Its not really related to your idea except for the shrink tubing part. It needs to be thin tubing too.
[ QUOTE ]
[/ QUOTE ]
This shrink tube is heavy, waterproof and has a "bonding surface inside, just happend to be the ones I grabbed.
Update..
This has proven to be an excellent way to carry spares, I made a few and left them around in places like my glovebox, dresser drawer and my pocket. It is the same size as the batteries themselves plus a bunch of protection. I have made minor modifications that allows the pack to be waterproof as well, I even made one for my keychain.
The bonding stuff inside is a heat activated layer, it is quite thick.
This has to get very hot to begin the process of "becoming sticky". I heated the whole tube till it was snug around the batteries, then with a lighter sealed the ends. I would not choose this type of shrink tube if you plan on getting at the batteries in a hurry, tonight my torch quit while I was laying in an attic with an angry squirrel.
Regular shrink tube would break fairly easily but not be water resistant, this stuff forms a rubberized skin around the cells.
No, the glue did not stick to the batteries.
