EDC light good for weapon use.
dhysk
I need a light I can carry with me everyday so the smaller, probably no longer than maybe 7 inches, and more importantly thinner the better. Since I will have it with me it needs low power modes because if I have it I'll use it. It also needs high impact resistance to hold up to being held in the hand with a handgun it's primary purpose. Basically a small 'tactical' light that has easy to get to low power modes.
I currently have an old, I mean OLD, mini mag 2 AA incandescent. I'd rather have something smaller I normally ware slacks and dress shirt so smaller is better. Long run times on med power settings 30-65 lumens. I'd like to run re-chargeable batteries but be able to put in alkaline in a pinch.
I have been looking at the:
Olite T-25 on the big side for sure.Quark "X" AA2 Tactical, I'm really split on the 2 programmable modes. I love the tight, loose pre-operation mode selection. Hate the other possibly useful modes being impossible to get to.
Preon 2 - maybe hard to actuate while operating a firearm. I prefer a kind of a cigar hold actuating the light on my strong hand.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
__X__Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
__X__Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
__X__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__X__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__X__I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__X__Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__X__30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
__X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
__X__I want a forward clicky (Helpful for momentary activation and signaling).
__X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
__X__I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
_X___I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__X__I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
__X__Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Just thought I'd ease your mind some and point out that the Preon 2 does have a clicky switch, so unless you switch it out for the twisty you shouldn't have a problem using it in your preferred cigar hold. To be honest I was thinking the Preon 2 the whole time reading your post... Then I saw that you're looking at it already. :)
One issue with multimode lights is that they can change modes on impact. If the battery moves enough to break the circuit momentarily, the light will advance modes. I do not use handguns so I can't speak to the actual impact experienced by a hand-held light in use, but I can thump some of my lights and change the mode without using the switch.
Is changing modes with a thump more prevalent with a certain type of UI, or is it a common issue with all multi mode lights?
Klarus XT2A, 2xAA (or smaller XT1A, 1xAA) + Klarus TR11 Remote Swtich (if mounting to a firearm).
(Marshall's video from GG: http://www.youtube.com/watch?v=c3X4dM-4YUQ <-- informational video)
The Klarus XT line has a UI that is popular with first responders, tactical users, and the armed citizen.
It depends on how the particular light changes modes. Some drivers simply switch within a certain time when power is on/off. Others are more complicated (dual switches, etc).
The recoil that most centrefire caliber firearms generate is more than enough to interrupt the circuit of a non-shock isolated flashlight.
Lights that are shock isolated, intended for weapon lights or otherwise, tend to have some sort of arrangement that applies spring force to both ends of the battery(ies) in addition to design implementations for the internal components (such as potting).
If you're hand-holding your light shock isolation is a non-issue (especially with any holds that bring the light away from the sidearm).
