EDC Light
xarr
Hey folks, hoping you can recommend me a new light, a simple EDC.
____I will be mail-ordering or buying online, so this doesn't matter (caveat; UK based).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than £100.
____I’m flexible, tell me what you got.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry small (2-4 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
A simple finish is better, I don't want or need a tactical look. I would prefer a light that I can select any level, needs to be able to go to a low/moonlight mode. I have been looking at the Nightcore EX11 v2 and Sunwayman V10R, any thoughts or further recommendations (these are at the upper end of what I would prefer to pay).
Thanks in advance =)
Sunwayman V10R (HA or Titanium) springs to mind.
Actually, after re-reading your "throw" requirements I'd suggest you look at headlamps, either the ZL H501 (best reading light I've got), or a H51f (not quite so good for reading, but a bit more throw).
Thanks for the suggestions, you missed this though:
3) Format:
The main purpose of this will be to stick in my uniform pocket on nights (I am a nurse). Checking on my patients using a head torch would be a little strange, plus I am a fan of Petzl headlamps.
I am pretty much set on the Sunwayman, but even to me £70 seems steep, but I guess its about the price you pay for the control ring (and in the grand scheme of things this isn't the end of the world, but after an expensive Christmas buildup spending more money is peverse!) Thanks for the other suggestions but I am not a fan of the SC51 design and would prefer a tail switch.
