Eiger QTC Efficiency---Runtime Tests (Updated)
AFAustin
outside of Austin, TX
In another thread: http://www.candlepowerforums.com/vb/showthread.php?323453-How-to-Tell-Eiger-Emitter ,archimedes persuaded me to do a little runtime testing, to compare an original Eiger Rebel #4 with an Eiger Rebel #8 with a "bare" QTC square installed in the tail so that it could be "dialed down" to approx. #4 level. He believed that the QTC light would be significantly more efficient than the non-QTC light in that the QTC converts almost no current to heat, unlike the resistor in a non-QTC light. I did 2 different tests, both of which were crude and run hastily, and without close monitoring of the lights, but with those caveats, here's what I got.
In the first test, I installed a freshly charged Duraloop LSD NiMH cell in each light, and dialed down the #8/QTC to approximate the total output of the #4. This was measured just by my eyeballs doing a ceiling bounce test in a dark closet.
As I said, I wasn't monitoring the lights closely (doing too many other things at the time!), and should have, but didn't, record when they first fell out of regulation and began to dim. (From memory, though, I believe the #4 is steady for about 4 hrs.) At about 5 hrs., though, I did see that each had lost roughly 1/3 of original output. But then things got interesting. At a little under 6 hrs., the #4 was now very dim (almost gone), but the #8/QTC still had a very useable output, maybe 1/2 of the original. I checked the cells at this point on my DMM. The #4 was at 1.13v and 3.1 mA. The #8/QTC was at 1.25v and 3.5 mA. Go QTC!
The #4 was played out, but I decided to keep going with the #8/QTC. But, I now cranked it up so that its output matched the #4's with a fresh cell (initial output). I then monitored the #8/QTC more closely, and continued to dial up the level as needed to keep matching the #4 original output level. By the time I had it cranked up all the way (it faded pretty quickly after that), the #8/QTC had run a tad more than 2 additional hrs. Very good results for the #8/QTC, I'd say.
I did a second test as well. This time I tested only the #8/QTC. Once again, I dialed it down to match the initial output from the #4. This time I wanted to see how long, with tweaking as needed to maintain steady output, it could maintain the initial #4 level. Again, my recollection is that the #4 can do about 4 hrs. of regulated output with little dimming.
The result was right at 6 hrs. That is, the #8/QTC, dialed down to match original #4 output, maintained it for 6 hrs., while the #4 can manage 4 hrs. Again, very nice results for the QTC set-up.
Not exactly strict science here, but I hope this is useful.
Andrew
UPDATE (and oops) : Please see my post #7 below....looks like the #8 Eiger is most likely an XP-G rather than a Rebel. Needless to say, this changes things quite a bit....Mea culpa. :ohgeez:
:twothumbs - Sounds like QTC provides at least 50% bonus runtime !
Interesting that it seems to particularly prolong the "tail" of the output/runtime curve....
Re: Eiger QTC Efficiency---Runtime Tests
Interesting. I like tests like this. Thanks for the info.
Are you positive that both lights used a Rebel emitter?
Paul,
I was pretty sure, till your question prompted me to check further, and now I'm not so sure. In the thread I linked at the beginning of this thread, I asked how to determine this very thing, as to the #8 Eiger I had just bought on the trade forums. As far as the #4, I bought that in '09 directly from Peak, and Eigers at that time were only made with Rebels.
But back to the #8. In the referenced thread, the suggestions I got for determining the emitter were that Rebels have a warmer tint, and that XPGs had a little "telltale green" on the board that could be seen with the light off. I also have a Fenix EO5, the 30 lumen version with an XPG-R4 emitter, and it also has an optic and floody beam. The Eiger #8 has a noticeably warmer tint than the EO5. And, while the EO5 definitely has a little of the "telltale green" visible around the emitter, I couldn't see any in the Eiger. Finally, while in my original thread Curt said that most of the Rebels had reflectors, I believe it is true that the "medium" beam width Rebel Eigers did have optics (someone please tell me if I have that wrong). So, I concluded that my #8 Eiger was a Rebel model.
But, as I said, your question prompted me to check further. As to the beam tints, my opinion is the same---the Eiger is noticeably warmer. But, this time I peered into the Eiger head with the help of a 15x lighted loupe, and there is a bit of green visible. It is less distinct that the green in the Fenix, and appears farther removed from the emitter, but that may be because it's harder to see into the Peak head than the Fenix head, due to how the optic is constructed.
So, now I am royally confused. Does the faint but definite hint of green in the #8 Eiger mean it has to be an XPG? I hope someone can give me the definitive answer on this.
I will also PM the nice gent from whom I bought the #8 Eiger and see if he might have some additional info. that could, ahem, shed some light on this.
Thanks for motivating me to dig deeper.
Andrew
Update: Thanks to the nice gentleman from whom I bought the #8 Eiger, I've learned the name of the CPFer who sold it to him. And apparently, that gent bought it from Peak, as my seller recalls. I have PM'd the original owner, but haven't heard back. His profile indicates he hasn't checked in to CPF for a while, so don't know when I might talk to him.
But, in the meantime, Craig (csshih) has been a great help in this emitter mystery, and his opinion, based on the "green" factor, is that my Eiger is very likely an XP-G: http://www.candlepowerforums.com/vb/showthread.php?270419-Commonly-Used-LED-Emitter-Index/page4
So, it seems highly probable that, tint issues aside, what I thought was an Eiger #8 Rebel is instead an Eiger #8 XP-G. The efficiency improvements shown in my crude little tests are still pretty significant, but now I can't say how much of that is due to the QTC and how much to the XP-G.
Of course, all of this just demonstrates why I never would have made it as a scientist. :shakehead
Thanks again to Paul for prompting me to dig deeper.
Andrew
