mtbkndad
- Joined
- Jan 1, 2005
- Messages
- 1,295
I just finished testing an ELX-12. This is one amazing LED light. For people that may not be familiar with Wayne Johnson's latest creation the Elektrolumens ELX-12 is a 12 x 3 watt LED light. The 12 - 3 watt LED's are matched up with 12 - 27mm reflectors. The model I tested was the ELX-12 20AA. The 20AA part of the title refers to the two parallel 10AA packs wired inside the light. This light comands attention whether on or off. It us just too big to be ignored. Here are a few pics to demonstrate what I mean.
Green 3D Mag, ELX-6, ELX-12
It measures 16 3/8 inches long. It weighs 4lb 6oz and the head is 5" in diameter.
This is a big imposing looking light.
Here is the complete setup.
The 20 AA pack consisting of two parallel 10AA packs delivered 60 minutes of bright run time. That was very nice and I consider that time to be quite reasonable. I tested the packs after charging them and they charged very evenly, this is important when dealing with parallel packs. For a battery run time test I took lux @ 1 meter readings every 10 minutes and here are my results. At the 60 minute mark I could still easily see the garage in the pictures below.
Start-----------28,590
10 min---------23960
20 min--------23,050
30 min--------22,720
40 min--------22,560
50 min--------22,030
60 min--------20,930
70 min--------14,760
When I do runtime tests I keep any light I use in front of our living room air conditioner set on low fan closed system. With this setting I am just recirculating the room air over the light. This is because I have found lights that may get quite warm when sitting for a runtime test do not get nearly as warm when in actual use, so a few months back I decided to start doing all of my runtime tests like this whether the light is incandescent or LED for the sake of consistency.
One other point, the batteries that were used were the 2500mAh Energizers that came with the light.
When I first read about this light I posted that Wayne may have created the first LED light that could be considered a "spotlight". When it came time to do some comparative pics that people could relate to, I did not have any conventional flashlights (LED or Incandescent) that could even come close. So I had to some more "unfair" comparisons for people to be able to get an idea of what this light is capable of.
The first series of photos will compare 4 lights a 10MCP Thor, a 3 MCP Dorcy, an ELX-12, and an ELX-6. The camera was set at 6" f 3.2 for these photos. The garage I am aiming the lights at is 370 yards away. This is the same camera setting I used when comparing my van headlights to the ELX-6 in the ELX-6 review.
10 MCP Thor
3 MCP Dorcy
ELX-12
ELX-6
When looking at the cropped images pay attention to the transformers at the top of the picture as well as the rest of the photo's
10 MCP Thor
3 MCP Dorcy
ELX-12
ELX-6
If you ave a very good monitor you can still barely see the garage in this picture.
Curiosity got the best of me, so I decided to take this with me to a Spotlight Shootout I was doing with Mr Ted Bear. I also had a brightstar with me and PGP had his too. The pics below are comparing one of my Thor's, PGP's 24 watt Brightstar , and the ELX-12. The camera setting was 6" f.3.5.
This is the same setting I used for all of the lights that night from the Ken 4 all of the way down to the ELX-6 20mm. I did not bring my daughter's Dorcy so this comparison will have a 10 MCP Thor, 24 Watt HID Brightstar, and the ELX-12.
10MCP Thor
24 Watt Brightstar
ELX-12
Thor
Brightstar
ELX-12
The 12 27mm reflectors do not produce as tight a beam as the Thor or Brightstar, but the corona is very bright and very even. The people at the shootout were rather suprised at how well this LED light did.
There were a couple of issues with this light that need to be mentioned.
The first is the lens retaining ring. Four bollts just do not seem to be able to hold the entire ring flush. This is not my opinion, you can see for yourself.
The gap is on half of the light. The half not photographed was fine.
When I mentioned this to Wayne he said he started using a screw on bezel for this light.
The other issue is that the rubber cap for the switch seemed to be working it's way loose after a couple weeks of testing. I know these are little things but this is not a cheap light.
Things that I really did like a lot.
The knurling felt very nice to hold. It provided great grip without being too rough.
The light has a very nice balance to it which made it very comfortable to carry around.
I love the fact that there is no warm up cycle with LED lights as opposed to HID's.
I like to use my lights as needed and not continously.
Over all this is a very impressive light both in appearance and performance.
It is much more blinding to be on the receiving end of this light then all but my biggest spotlights. The reason for that is twofold.
1. The color temerature of the LED's is very irritating to most people's eyes when looking at them.
2. The 12 LED's in their "little" 27mm reflectors will catch a persons eye much faster then my spotlights with their bigger reflectors. The spotlights need to be pointed almost directly at a person to be real blinding. The ELX-12 will be much more blinding much quicker when seeking to use it in this manner.
The night before I sent this light back something was attacking my wife's chickens. I had numerous lights in the room I could grab including 5 different HID spotlights, Two halogen spotlights, the ELX-12, and an ELX-6. The light I immediately grabbed was the ELX-12.
The maruarder turned out to be a racoon. I blinded it with the ELX-12. It just froze while blinking it's eyes. Because of it's obscure position I could only whack a club next to it and it then wabbled out of my yard and did not return that night. In this circumstance there was no real choice, the ELX-12 gave me immediate blazingly bright light that was utterly blinding to what I knew was going to be some animal.
I do like this light and plan on getting one at some point. The price is a bit of a question mark as Wayne of Elektrolumens is working on two different configurations.
ELX-12 20AA and ELX-12 6D. The 6D model is currently $349 without batteries or a Charger. If I remember correctly the ELX-12 AA was originally $499 as a complete setup and around $360 or $370 for the light wired for 20 AA's but with no batteries or charger.
The reasons I am not getting one immediatley are-
1. I am curious to see how the 6D version performs in terms of brightness and run time.
2. I have funds for non daily use lights allocated in different directions right now.
I do not personally consider the ELX-12 a daily walk the dog light. I have an ELX-6 20mm and an ELX-6 27mm on order for those duties. The ELX-12 is a light I will keep around the house fully charged and accessible for those times an overpowering amount of light is needed immediately, either for illuminating object and areas, blinding masked marauders, or both.
Take Care,
mtbkndad :wave:
![3Top.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F3Top.jpg&hash=a76adbe988e9ec9e031959b3eefdbd5f)
![3UpFront.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F3UpFront.jpg&hash=2ea9eb4c121c15102dad0ed990197f32)
![TapeMeasure.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FTapeMeasure.jpg&hash=b3e0e22c4a34de77a3b00a9eaf9c8cb1)
![TheFront.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FTheFront.jpg&hash=4e9e408503d143d19b7eeaeaa61af73c)
![CompleteSetup.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FCompleteSetup.jpg&hash=5ab5deb0cf4482d3a33c99aa196eb507)
![10MCPThor.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F10MCPThor.jpg&hash=7d7406c1e8bc10b07803caf1737618da)
10 MCP Thor
![3MCPDorcy.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F3MCPDorcy.jpg&hash=d9f0751103d2f70c6a01ecaf89fa4ca1)
3 MCP Dorcy
![ELX-12.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-12.jpg&hash=0682b1100df79bc298bcf1d07645312d)
ELX-12
![ELX-6for12.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-6for12.jpg&hash=739768d154e9ac6b86035aeb99cc89ee)
ELX-6
![10MCPThorCrop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F10MCPThorCrop.jpg&hash=6d9917c9a2b741f82e966eef7be79ee5)
10 MCP Thor
![3MCPDorcyCrop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2F3MCPDorcyCrop.jpg&hash=6ebdf4e2f139ae815ed875081a844496)
3 MCP Dorcy
![ELX-12Crop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-12Crop.jpg&hash=9ea0cc1e10dd399120d9f076bef62671)
ELX-12
![ELX-6Crop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-6Crop.jpg&hash=5d2286d07f039aa3fe41cb807f37d3a5)
ELX-6
![ThorTree.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FThorTree.jpg&hash=db9ed7b80a7a7362c0eff631f334356c)
10MCP Thor
![Brightstar2.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FBrightstar2.jpg&hash=4d93c720828b6e316dcf074d7403927d)
24 Watt Brightstar
![ELX-12Tree.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-12Tree.jpg&hash=7a7eaaeb38aef6228741028a1cfd8e43)
ELX-12
![ThorTreeCrop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FThorTreeCrop.jpg&hash=a6bdbc6d5aadc2c1ad43dfe15c0c3ecf)
Thor
![Brightstar2Crop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FBrightstar2Crop.jpg&hash=9ea9c82ecfdca5223f59f4c3fccc4161)
Brightstar
![ELX-12TreeCrop.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FELX-12TreeCrop.jpg&hash=77ad8fc72aca38072775d5d76860e568)
ELX-12
![RingGap.jpg](/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv650%2Fmtbkndad%2FRingGap.jpg&hash=32944e27ed09459a25f10e6ba2eaae23)
Take Care,
mtbkndad :wave:
