mtbkndad
- Joined
- Jan 1, 2005
- Messages
- 1,295
When I was doing the Stunner prototype review Wayne sent a Little Friend down do me.
I was very busy with work and have finally been able to complete a review of this wonderful little light. The little friend is a direct drive 4AAA 3 - Luxeon 3 watt light. The best way to describe it is a personal pocket flood light. It has two levels, low and high with off clicks in between.
off - high - off - low - off ...
I like this setup because I can set it in advance for the output I anticipate using next. I have the same type of switch on my two ELX-6's. I also like the groovy texture of the Little friend. It gives the light a very smooth yet easy to hold surface. When the light arrived the Type 2 anodized finish was very nice. Unfortunately, in the testing process the Little Friend did suffer a few drops which show up in the photos. Sorry Wayne, I hope you are planning on keeping this one for yourself when you get it back . I can say it is a fairly tough little light.
Since most people originally asked how it performs in relation to a Tri-star Phaser and I have one. I decided to use my Phaser and 9V Falcata for comparison pics. My Phaser for the obvious reason of answering people's questions about how the two compare and my 9V Falcata because it is a similar priced relatively compact incandescent light.
In reality the Little Friend has about half of the light output of my Tri-Star Phaser. I am using the batteries Wayne sent down with the light since I do not have any Titanium NiMH AAA's at the moment. I do not know if Titanium's would give a little better light output or longer run time. The reason I mention this is because I consistently have gotten better run time results using Titanium NiMH batteries then the batteries Wayne sends with his lights to test.
By saying this is about half as bright as my Phaser I not saying it is not bright for it's size, rather the mini tri-optic and the 4 AAA's just cannot put out the same amount of light as the full sized tri-optic and 4 C's of the Phaser. Wayne's run time estimates are right on the money. Actually I only did the runtime test for high and decided to take Wayne's word for the low because I did not have the time to do a 2 hour run time test. Here is my runtime test result on high.
Time PM ---- Lux@1 meter
6:10 ---- 1401
6:15 ---- 1325
6:20 ---- 1386
6:25 ---- 1351
6:30 ---- 1387
6:35 ---- 1142
6:40 ---- 534
My Phaser with a similar beam and WIDER pattern starts at around 2700 lux at one meter.
For photo's I chose to push the Little Friend to it's limit.
The photo's were done at f3.5, 8".
The Trailer down the street is 180 feet away. All three lights are focused on the trailer. Unfortunately the Suburban happened to be parked on the street the night I took the photos. I like to shoot shots toward the end of the effective range of lights because beams that look white against a wall show their true colors when shooting toward the limit of their effective range. It is the corona of the lights that is illuminating the Suburban.
To the right of the Trailer in the 9V Falcata shot and Phaser shot is a white dot, also barely in the Little Friend - High shot if you have a REAL good monitor. That dot is a white garage door 130 yards away. Unfortunately a car was driving buy in the Phaser shot so the dim garage door is harder to see. The garage is way back off the street and the Phaser did not get any help from the passing car headlights in illuminating the garage door. Notice that a car also drove by in the "no flashlight" shot and there is no garage door to be seen on my 17" powerbook. One final note- If you do not have a nice monitor you may not see that white dot that is the garage door in any of the shots.
No Lights
9V Falcata
Phaser
Little Friend - Low
Actually the cropped shots show just how well the Little Friend did at this long distance. Remember this is a little flood light so 180 feet is really asking a lot from this little light.
No Lights Flashlights
9V Falcata
Phaser
Little Friend - Low
Now for some more reasonable shots. In these photos the lights are focused on the tree trunk that is 90 feet away. The Yellow fence in the background is 132 feet away.
First another night shot
9V Falcata
Phaser
Little Friend - Low
Even on low the yellow fence can still be seen.
Now for some cropped shots of the tree and yard.
9V Falcata
Phaser
Little Friend - Low
Wayne sells the Little Friend's for $119. This is a nice price for such a small little flood light. I really have enjoyed using it for lighting up a decent area with a nice even flood of light. Low is very useable and I like to save high for getting attention or when I need a lot of light very quick. The fact that is uses 4 AAA's is nice because AAA rechargeable batteries are relatively inexpensive and also very small and light, so extras can be carried . What I do not like about the light is that everything is in such a tight space that care must be taken to put the battery holder in just right in order for the tail cap to be able to screw down completely.
Over all I am very pleased with the Little Friend and will miss it when I send it back. It is no Tri-Star Phaser, but it is a very nice little light. At the same time the Phaser may be brighter then the Little Friend, but it can't be conveniently placed in a jacket or coat pocket and be ready for use at a moments notice like the Little Friend. I you like the beam characteristics of optics in general and Tri-Optics in specific then this is a wonderful little light to have. I personally think it is too big for pants pockets and small purses, but if the lady in your life uses a medium to large purse this may be a nice addition. It also fits quite comfortably in a jacket or coat.
Take Care,
mtbkndad :wave:
6:10 ---- 1401
6:15 ---- 1325
6:20 ---- 1386
6:25 ---- 1351
6:30 ---- 1387
6:35 ---- 1142
6:40 ---- 534
No Lights
9V Falcata
Phaser
Little Friend - Low
9V Falcata
Phaser
Little Friend - Low
9V Falcata
Phaser
Little Friend - Low
9V Falcata
Phaser
Little Friend - Low
Take Care,
mtbkndad :wave:
