I've been studying the effects of enclosures on CFL performance and would like to confirm something with regards to power draw. I tested the same CFL bulb in a tube-up orientation both with and without an airtight enclosure around the ballast and tube, and measured the ballast temperature and the power draw. The light was left on for 1 hour to reach steady state, and ambient temp. was 69 deg F. I bored a tiny hole through the case of the ballast to poke the thermocouple in, and it was fastened to not move between the two tests.
Granted, my sample size is one and I'm not applying PF correction to get true power, but I was more interested in the difference between the two cases Here are the results:
CFL tested: GE 71804 15W spiral
Uncovered:
Ballast temp: 112 deg F
Center of Tube temp: 105.6 deg F
Power draw: 97.7 mA (AC) (Correction: This is on a lower lamp setting)
Covered:
Ballast temp: 114 deg F
Center of Tube temp: 180 deg F
Power draw: 79.6 mA (AC) (Correction: This is on a lower lamp setting)
This suggests an 18% reduced power draw when the bulb is enclosed. For those CFL gurus here, does this make sense or is there something else going on? Does the vapor consume less power when it's hot? And will the phosphors give out at these higher temperatures, eliminating any gain from the power improvement?
Uncovered:
Covered:
