Corona
I've noticed the Elly (MXDL 1W) that I've used for a violet laser project has trouble starting with a partially discharged alkaline. It won't start at all with a NiMH cell.
When it is in this mode, loosening the tailcap a bit and tightening it again seems to help get it to fire off. Working the clicky doesn't have the same effect.
Is this a common issue, or is the one I have dodgy?
I suspect this is either a connectivity problem via the anodizing on the 2 aluminum mating pieces (tailcap & body) or some inherent startup voltage issue with the wee little boost controller IC.
Perhaps the act of making an intermittent connection introduces small voltage spikes on the controller and allows it to start. I'm going to try adding a small tantalum cap right on the PCB and see if it makes this better or worse...
It's easy to see that the boost controller's 3 pins have these functions (left to right looking at it with the heatsink tab at the top)
Pin 1 - Negative supply rail
Pin 2 - Boost voltage input (positive supply for IC and sense input for boost voltage regulation)
Pin 3 - External FET gate drive output
EDIT - found the datasheet, it sure looks like it's a Rohm RH5RH!! Supposed to operate down to 0.9V at light load
Hmmm...
Hmmm...
