etc
Sanyo Eneloop is that new low-discharge technology, but it's rated at only 2,000 mAh. However Sanyo or Maha Powerex are both rated at 2700 mAh, or 30% higher - and it takes a long time for them to discharge 30% to the level of Eneloop. A month maybe, or more.
For heavy duty equipment, cameras, flashlights, radios, the higher amps cells win, unless you need to store them for a long time.
I've used both and the only difference is that Eneloop cuts out sooner than others at higher amps.
Until Eneloop comes out with a similar capacity, it's not a real competitor with dominant cells.
