idleprocess
QUICK SPECS
PHOTOS
FLat View
Perspective View
EverLED installed in 2C mag host
EverLED beam at ~15" in 2C mag host
Stock 3V PR bulb beam at 15" in 2C mag host
bare EverLED at ~15"
bare 3V PR bulb beam at 15"
EverLED beam at ~15'
Test scene with florescent lighting
(Snide) COMMENTS
- Light source LED - Luxeon I
- Type PR-base incadescent replacement
- Operation depends on "host"
- Driver Boost/buck circuit
- Power source 1-6x 1.5V cells (1.5V - 9V)
- Focus Available in side-emitter and lambertian beam styles
- Cosntruction Brass PR bulb base
PHOTOS
FLat View
Perspective View
(Snide) COMMENTS
- Drop-in PR bulb replacement capable of functioning in most PR bulb sockets
- Excellent Luxeon tint on sample unit
- Beware of 6V lanterns with reversed polarity - use "Diamond" EverLED instead
- Output may be disappointing in larger lights (although runtime should be greatly increased)
- Exercise caution with plastic lights - unit needs some sort of thermal path to shed heat
- Light pattern is similar to host's regular beam
- Unit is a bit pricey - typically $35-$40
- Suggested use: permanent replacement bulb for your favorite PR lights
