If I'm not mistaken I think that the original is a 2600mah nicad pack so I really don't believe the 200% longer runtime claim.
I sold my SL-20 long ago, but I recall the capacity was in the 2.2 - 2.6 range. If the original pack is indeed 2600 mAh, to get "200% longer" runtime (100% longer would mean doubling the run time), you would need a pack with 10,400 mAh, not 3500 mAh! Lower down in the ad he contradicts himself, saying, "... MORE than double burning time than OEM NiCd battery..." If the original pack is 2.6 Ah, a 3.5 Ah pack is no way going to MORE than DOUBLE your run time. You would be lucky to see a 25% increase, not 200%, or even 100%. Sheesh, some salespeople...:shakehead
Actually if a Streamlight 20X gets X amount of an hour with the stock battery pack, say rated at 2200mAh, you will get about 2X runtime using a battery pack correctly rated at 4400mAh. Bill
It's not unbelievable. However, I would get the one from Battery Junction...Is this true and worth it?
EXTENDED BATTERY FOR STREAMLIGHT SL20X SL20 SL20S
3500 MAH SUPER EXTENDED!
Yes, understood. My point of contention is in some people's misconception that "200% longer" means "2X longer", when it actually means 4X. If a light runs for one hour on, say, a 2200 mAh pack, and one uses a 4400 mAh pack and gets a run time of two hours, the run time is 100% longer, or 2X. There is a difference between saying, "the run time is 200% of that of the stock pack," (2X longer) and saying, "the run time is 200% longer" (4X longer).
