Fenix E05 R2 & E05 R4 officially released!
Status
Not open for further replies.
daf3m
Straight from Fenix ( http://www.fenixlight.com/viewnproduct.asp?id=78 & http://www.fenixlight.com/viewnproduct.asp?id=77 ) :
R2:
• Uses Cree XP-E R2 LED with a lifespan of 100000 hours
• Uses one 1.5 V AAA (Ni-MH, Alkaline) battery
• 64.5mm (Length)?14.4mm (Diameter)
• 11.3-gram weight (excluding batteries)
• Digitally regulated circuit - maintains constant brightness
• Reliable revolving switch
• Capable of standing up securely on a flat surface to serve as a candle
• Premium Type III hard-anodized anti-abrasive finish
Note: The above-mentioned parameters (tested by 750mAh Ni-MH battery in the lab) are approximate and may vary between flashlights, batteries, and environments.
R4:
• Uses Cree XP-G LED with a lifespan of 100000 hours
I think you must have been nodding off,we all know already a thread about the EO5. :crackup:
The existing Fenix E05 thread is here - you've posted in that thread previously. :thinking:
Also, please don't hotlink images from other websites. Deleting the 32 hotlinked images from this thread of yours, plus the 18 hotlinked images from your other thread this morning, plus closing both of them since there are already existing threads on these two lights, plus doing two searches and posting the links to the existing threads - this is a lot more cleaning up than I'd rather be doing in /LED/ this morning. :mad:
Status
