Fenix LD / PD range question
Smith28
Any chance someone could clarify for me the diameter dimensions of the PD / LD series?
Looking at various websites it seems that the LD range and the PD range have the same diameter.. Is that actually be true?
So comparing a LD10 (slimmer cell - 1x AA) and PD20 (thicker cell - 1x CR123) the thicker celled light is actually the same width as the thinner celled light? So actually proportionally smaller. So comparing the PD20 and LD10 you get a light of the same diameter but shorter length with more power and longer run time. :duh2:
Then you have the new upgraded side switch versions - LD12, LD22, PD22, and PD32, are they actually any wider in diameter vs the older versions and vs each other?
I've found about 3 or 4 different diameters listed for different models around different sites.. Very confused, hope someone can help.
:grin2:
