half-watt
been using a 3xCR123A battery tube with some P3D's that i own (both smooth and textured reflectors; both Q5 and non-Q5 emitters).
i really like the new tube. same length, essentially, as a 2xAA L2D-CE tube. so, for my tastes, about as long a tube as i would want to pocket/EDC on a Fenix.
it should really increase the burn time i expect.
there is one phenomenon i noticed with the several P3D heads i tried.
perhaps the batteries were to blame??? don't know.
used three new Tenergy CR123A's in the new tube and used two older, slightly used Duracells in the original P3D tubes. this would favor, perhaps, the newer Tenergy batts, but the side-by-side tests reveal otherwise.
performed a side-by-side visual test (no light meter - sorry).
compared two Fenix at a time, side-by-side in a dark basement room with with white walls (never owned a camera, so, again sorry, no pics).
switched each head from the original tube to the 3xCR123A tube. kept it's tailcap switch with the head - whether on original tube or 3xCR123A tube.
in ALL cases/comparisons (Q5 v. Q5, non-Q5 v. non-Q5, smooth v. smooth, textured v. textured) the light was brighter (compared only the LOWEST output level) when the head was run on the original 2xCR123A P3D tube than it was on the 3xCR123A tube. the differences were very slight and barely noticeable in some cases, but more noticeable in others.
to illustrate: let's call one light A and the other B. A starts out on the original P3D tube and B on the 3xCR123A tube. A is brighter (on the lowest output setting) than B. Now, placed A on the 3xCR123A tube and B on its original tube (NOT the same original tube A started out on). B is now brighter than A. [Note: tailcaps followed heads]
i repeated this test for all possible, similar combinations (e.g., two Q5 smooth, two Q5 textured, two non-Q5 smooth, two non-Q5 textured, i.e. two lights compared at a time, even if 3 of one combination were in my possession).
in ALL cases the heads were brighter, on the lowest output levels on their original tubes.
at higher light levels, they seemed the same to my eyes - they're all just so bright at ~20' (the distance employed in this side-by-side test) indoors with white walls.
seems like, when run on a higher voltage, the buck converter might be "dialing" back the current just a bit for the lowest output mode??? don't know.
basically, i just like to know if anyone else has noticed something similar. light meter results would sure be more telling here - i would imagine. anyone have any thoughts on the reasons for what i observed? would appreciate being educated by someone on this point.
in my case, i'm still very pleased with the 3xCR123A tube and would recommend it as an upgrade to anyone's P3D. haven't yet determined burn-times on the 3xCR123A's, but it probably allows me to run on 50/53lumen output when i'm out and about at night instead of the 9/12lumen output and still achieve adequate (for my purposes) burn-times - a very nice improvement indeed.
