First time post and unfortunately I'm asking for help. I recently purchased a Fenix PD32UE from Shaologear. I also have two Panasonic (green wrap, Made in Japan but no Panasonic label) NCR18650B 3400mah protected from Fasttech which I use in my budget light. So here's the problem: I put the battery in the Fenix and the light is already on. I push the tail button but the light stays on. Check the switch with a meter and it's ok for both full and partial push. The only way to turn on/off is to unscrew the end. With the light stuck on I select the various modes and all work except that burst seems just as bright as turbo. A buddy of mine has the same light. We swap tail buttons with no improvement. He uses CR123 batteries. We swap batteries and now his doesn't work right but mine does. Thinking that maybe the battery is somehow shorting out the button I cut a piece of electrical tape like a donut and place it over the negative end of the battery. Now the light doesn't come on without pressing seriously hard on the switch. The battery measures at just a hair under 70mm.
I contacted Fenix explaining the situation and received a response stating that the PD32UE can use rechargeable 3.7 V18650 Li-ion battery and CR123A batteries however the NCR18650B batteries cannot be used. I ask why it is not compatible and which ones are and was told to use 2600 mAh 18650 and that the NCR18650B battery is 3400 mAh.
This wasn't exactly the response I was expecting. How is it possible for battery capacity to have an effect on flashlight circuitry?
In the meantime Shaologear and I have agreed to return the light with one of my batteries to see if they can diagnose this situation.
What do you guys think? Is this a compatibility issue? Did I get bad batteries or light?
