Fenix TK70 Beamshots
ILIKEFLASHLIGHTS
Thought I would show you boys a 60yd beamshot from my Fenix TK70.
Manual setting 0.7 sec shutter 4/F ISO400
Re: Fenix TK70 Beamshot
It looks pretty but without a comparison shot against another big thrower that could be a ten dollar Costco pocket light depending on the exposure tricks that one can play with the camera and computer. That T70 can go 600 yards, so of course it would look great at 60 yards. Comparisons with the same scene setting and camera exposures are the only way to see just how good one light is against another. The way Goinggear does his is a perfect example. The barn could do with some paint.
Alrighty then.
Crelant 7G5 same distance and settings above
Olight M3X
Sunwayman T40CS
FandyFire STL-V6
Control shot
The T70 sure does have a wide spill and plenty of light on the subject.
Like rufus001 said, can you do some longer distance shots to stretch the legs of all of the lights as the TK70 is supposed to be a thrower as well.
I am not putting crap on your work, it would be nice to see real life shots from people that actually own and appreciate their collection.
Whilst at the same time giving others a good comparison to help base their purchase decision on.
Cheers
Great shots! That TK70 is a monster, some longer distance shots would be cool..... :grin2:
I have this light and it is beast. It throws with the best of them. U not only get the long distance, but it lights up EVERYTHING in its path along the way!!!
Nice job!
And, yeah, the barn still needs some paint.
:nana:
I find for throwers with flood, like the TK70, SR90, etc...you need a LONG wide field with reference points on it...points you can say how far they are away, etc.
A lot of us use google earth for these long shots...as frankly, MEASURING the distances is a PITA.
:D
I use power line right of ways a lot, as I get both transmission towers and often telephone poles, etc, at known intervals, to act as reference targets.
A lake with a shoreline that you can make out is good too, as you can typically pan along an opposite shore/bank, and get a variety of shot distances from the same shooting point.
I find I need a tripod for the camera to make the long shots work at all. My early attempts were too blurry.
I use a note pad to record what I saw for the shots, as I typically forget a few hours later when uploading the pics.
For example, I might note I can see the 7th pole by eye, but not the 8th, and the left side but not the right of XYZ, etc...so later, when I post it..I can make sure its showing what my eyes saw.
Otherwise, the pics are too dark sometimes, and stuff my eyes saw looks black in the pic...or, too exposed, and stuff I couldn't make out with my eyes does show up in the pic.
I can then play with the exposure to make the pic show what I actually could see when there.
Luckily, with my new camera, its more or less spot on if I leave it on auto...the old camera was more of a PITA to correct things for. My only real deficiency with pics, now, is that with my computer screen, I see what was there...but when posted here at 800 pixels...the pic is solid black, as 800 pixels is not enough for say a very small dot of light from an aspheric light on something really far away...and its invisible online. If allowed to post at full resolution, you'd see maybe some leaves lit up 600 meters away...at 800 pixels, you see a black box.
:D
The other thing I started doing was to take a Pic of the LIGHT I was about to beam shot...so the pics have start/stop pics that make sure I don't forget which light took which shot...as some pics CAN look similar depending on the target (Some targets don't illustrate the differences in beam as well...like I had a bunch of shots of the top of a telephone antenna pole, which resulted in dozens of pictures of a few feet of antenna glowing in the dark, in mid air....and little evidence of the width or intensity on that bright line). It was a bad target...and I had to abandon it.
Typically, you want the widest target possible, as that really gives a good picture of from where to where the beam's hitting.
Well these may undercut the light some, but the same settings as the others above.
TK70 200yds to trees behind last pole
TK70 350yds to horsebarn
And I'll add that those pictures all taken on 0.7 sec shutter is a lot faster shutter than a lot of guys will take on here with like 2 or 3 sec shutter.
I'll show you what I mean.
This is just 20yds farther than the 200yd shot above but on 2.8 sec shutter f/4 ISO200.
And here's what the 350yd shot looks like on auto with 2.5 sec shutter and f/4 ISO200.
Nice.
What settings/pics, to your eyes, looked like what you saw?
Fenix TK70 350yds 1 sec shutter f/4.5 ISO400
Fenix TK70 350yds 0.8 sec shutter f/4.5 ISO400
Crelant 7G5 350yds 0.8 sec shutter f/4.5 ISO400
Olight M3X 350yds 0.8 sec shutter f/4.5 ISO400
Control Shot 220yds 1 sec shutter f/4 ISO 400
Fenix TK70 220yds 1 sec shutter f/4 ISO 400
Crelant 7G5 220yds 1 sec shutter f/4 ISO 400
To ILIKEFLASHLIGHTS,
These are very good comparison shots.
I am going to start posting some of my own shots when I find a good location.
I just bought the Fenix TK70 with 8 x Premium White Tenergy 10,000mah NIMHs in it and a good Tenergy charger.
I already have the Olight SR90, M3X, SR50 and SR51.
I have the good old reliable Stanley HID 3000 (25 minute runtime) and modded Maglites.
I have the Dereelight collection of Aspherics and reflectors especially the great DBS-T Aspheric with the 9mm EZ900 Led with multi mode and multi battery options running on 2 x 18650s using optional extenders.
I also have got the nice new Thrunite TN31. (Fast becoming my favorite)
I am even thinking of buying the Thrunite TN30 (3000 lumens) because of its flood ability and the same battery case and body. I can play swapsies and have a second battery.
I used to do a lot of photography involving low light situations on real film and slides.
Tripods are a necessary evil in having to carry them around to get good shots.
I have a smaller tripod and a bigger Video Camera tripod.
I will start soon now I have enough flashlights to start comparisons.
I am still shy about buying the Crelant 7G9V2 with Collimator Head until I see what the electronics and reliability turn out to be like.
I had a Crelant 7G3 which gave my mates and I no end of mode switching and other troubles like the original 7G5 had.
I just had my dealer show me the new Olight M6 Marauder 5000 lumen light at night on his rooftop parking area overlooking the industrial area and man does that thing blast everything in site. A bit awkward to use and belt carry the battery but what output it does have.
Keep up the good work!!!
Cheers
