Hi All,
I am after a constant current circuit that I can use to provide a constant current e.g. 30 mA for a 3.4 volt LED from a 4.5 volt battery. I can make one using an npn transistor, but it will only operate down to 1.2 volts more than the LED voltage, so I thought a FET one that only requires a a couple of hundred millivolts more than the LED voltage would be ideal in this situation.
I read a post previously on CPF where a 'Magic Resistor' circuit using a FET is used, that will drop to below 1 ohm as the battery depletes, and I would like to try and do this.
I have a bunch of ST72A FET's at hand, but I am a little unsure of how they can be utilised.
Any help will be greatly appreciated.
