brightnorm
- Joined
- Oct 13, 2001
- Messages
- 9,027
There has been much debate in CPF over the issue of leaking flashlights. Consternation has been expressed over the disappointing performance of some of the finest lights and numerous fixes have been proposed.
Is our concern warranted? Is the issue less critical than we have assumed? Inspired by the following provocative post I decided to put the E2E/KL1 and the UK 2L to the test.
Noah Monk
newbie
Reged: 12/22/00
Re: A thought about water resistant flashlights. #197527 - 03/13/03 11:53 AM Edit Reply Quote Quick Reply
Hey guys, ALL flashlights are water resistant in my experience (fresh water). Try submerging any flashlight in water w/fresh batteries, switch it on and let the batteries drain. Even if the flashlight fills up with water (i.e. has very low water resistance), I think you will find it will work just fine while submerged and will sustain no damage. Of course, this does not apply to salt water or other highly mineralized water (such as hot springs). The whole waterproof thing is highly overemphasized. While waterproofness may in some way satisfy a perceived (i.e. not real) need, apart from underwater and/or extended use in very humid environments, there is no real use for waterproof lights.nm
TEST 1
Both lights, loaded with fresh SF 123’s were fully filled with water (within limits of closure), turned on and immersed in 8” of water. Two hours later both were blazing away, apparently unaffected by their ordeal.
TEST 2
The E2E/KL1 was turned off but kept underwater as the KL1 was removed and a standard bezel with MN03 was submerged and attached to the E2E which was then successfully turned on remained on for 20 minutes, at which point both lights were removed, turned off and emptied but not dried. The lights and batteries are currently air drying and will be retested tomorrow.
I didn’t have time to make this a thorough or extended test, and I would hesitate to put my most expensive lights through this ordeal, but I am reassessing my assumptions about water resistance/”waterproofness”.
NOTE: Several months ago I performed a similar test on an ARC SLS1 (2AA lithium) which initially passed the test but subsequently failed and was disposed of.
Brightnorm
Noah Monk
newbie
Reged: 12/22/00
TEST 1
TEST 2
Brightnorm
