Finally got motivated to fix my d20
netprince
I finally got tired of finding my d20 turned on because it had gotten bumped in my pocket. Yes, yes, I know it has a lockout, but that is beyond the point. Someone else figured out how to use a spring to fix the bump problem. I couldn't find a spring, so I took the unused strap from a maglite switch and wrapped it around a small screwdriver. I cut it down and soldered it on. Works perfectly!
We'll see how long it lasts.
Just a warning for anyone trying to solder to the + post. The + post is soldered onto the board, so when you solder your spring on the post, be careful not to slide the post to create a short.
