Firefly 3
MarNav1
Nebraska
I just bought a Firefly 3. Can't seem to get it to change modes. I charged the
battery with no help. Any thought's?:ohgeez:
I recall a Fenix being run on a 3.7v battery [instead of a 3.0v battery] that would not change modes. Are you using a Li-Ion 3.7v rechargeable?
65535 said:
Low is tightened only slightly high is hunkered down all the way.
A FFIII is controlled by a FLuPIC. It's level's are changed by quickly turning it on and off.
That's not it. With the FF3, on is on. Hunkering it down all the way will just dent the battery. You go through the modes by twisting on off on off etc...within .8 seconds between switches. If it's not going through the modes like that, It might be the battery. Once you see the chart for going through the modes in the different user interfaces it's pretty easy. I find it more intuitive than my HDS.
