First EDC LED torch?
RecklessRelentless
I'm looking for my first EDC LED torch. I really don't know anything about flashlights at all. I would like something that could hang off my keys, so not too big but not too small. Something under $100, preferably under $50. Around 1000 lumens if that's at all possible. Thanks. Suggestions?
That might be too much lumens to expect from a keychain light. Wait for the experts to chime in though
I don't know of any keychain lights anywhere near 1000Lm. I also don't know what you consider keychain size.
The very top sticky in the "recommend me a light for..." forum is a checklist of the info you need to provide in order to answer your question.
1000 lumens from a keychain is most likely not possible, however again I don't know how big you you consider to big. That checklist will help us all help you best.
My only advice I can offer is DO NOT DO NOT DO NOT take lumen ratings from eBay/amazon/any big-box type stores as anywhere near the truth. There is a wealth of info here, we can get you a GOOD QUALITY ligt that can do everything you want (within reason). But we need a good clear description of your expectations and you can best provide us that by using the checklist. You don't have to spend lots of money to get a good quality light.
If you can wait a few weeks --- the Fenix PD35
"PD35 - update to the PD32UE, 950 max lumen (burst), new XML2 led (highest efficiency LED on the market), June release"
Okay when I say keychain, I guess I misused my words. I just want something I can carry with my keys, not necessarily on them. Something similar in size to a mini compact flashlight, with a clip, maybe 50 to 60 or 70 mm in length.
if don't concern about the lumen, the thrunite Neutron 1A or Archer 1A is good,
hi,
1000 lumen definitely too high for a torch.
basically, manufacturers use the most simple, 5mm lamp, with viewing angle 15 for this.
<8lm is more than enough.
I ordered the TrustFire MINI-02 from Fasttech. I haven't received it yet, so I can't give you an opinion, but I did a little research and this seems like a great, cheap light that should last you a while with a 16340, while not taking up too much space like an 18650 light would. I'll let you know my opinion of it when I get it, but you're getting a tiny XM-L light for $15, so you can't go wrong here. It has good reviews as well (4.9/5)
