First flashlight?
I think with the 1 18650, it gives you 600 lumens, not 500......right? The RCR123's aren't recommended, that sucks. Should I stick with the cr123's or go with 1 18650 though?
CR123's aren't rechargeable, so stick with the 18650. And don't worry that you might have "only" 500 lumens. 500 lumens is super bright. I am fully confident that 500 lumens will make the stingers at your work look like single flame candles by comparison. :cool:
I wouldn't mind if it was only 500 lumens lmao, but I was just saying, they advertise it at 600, so that's what it should be if I am purchasing it based on what they advertise. Otherwise, how would you be able to believe anything else they advertise or sell? I am still super stoked don't worry. I will just have to buy a 18650 online somewhere, any suggestions on where to go to buy a quality 18650 battery?
To clarify the lumen/turbo jargon:
Turbo is like sprinting, and the "high" is like running, medium like jogging, and so forth.
Turbo is to get a peak at MAX brightness/range...a way to sprint when you need to.
To avoid overheating (Just like the runner), it steps down from turbo after a few minutes.
The brightness on the XT11 is controlled by the VOLTS from the cells. The RUN TIME is related to the mAh of the cells themselves...higher mAh = more run time.
So, the 18650 has ~ 4.2 v, and there's one of them, so the light's brightness is from the ~ 4.2v
The 18650 also has up to 3100 mAh to use for run time.
The CR123's are also ~ 3.0 v (Primaries), but there's TWO of them, so a total of 6 v for added brightness.
The CR123's are also ~ 1,500 mAh, less than half of the 18650's 3,100 mAh for ~ 1/2 the run time.
The RCR123's (Rechargables) are ~ 4.2 v like the 18650's...but - again, there's TWO of them...so that's 8.4 volts for even MORE brightness.
The RCR123's only have ~ 750 mAh though, about half of the Primaries' 1,500 mAh, for ~ 1/2 of THEIR run time (~ 1/4 of the 18650's run time)
For the circuit on the XT11, you add volts and mAh stay the same in this case. Some other lights are wired the opposite way, so brightness is the same, but run time is additive, and so forth. (Series vs parallel, etc...)
So, when you boil down the options, you can have your fire burn longer, or, use up your wood faster but have it be brighter.
:D
At Photon Fest 18, we measured some lights, and the XT11 put out a bit over 600 lumens on turbo with an 18650, stepping down to ~ 500 L when it got hot. When its cool, you have the ~ 600+ L again.
The same light with RCR123's was pumping out 850 L though, AFTER running long enough to step down....a LOT brighter...but instead of ~ 2.5 hours of run time with 3,100 mAh of cell endurance, we are down to 750 mAh, more like a half hr of total run time.
Almost all lights now a days step down to avoid over heating. Some advertise it, some don't. In the olden days, the lights would either just not HAVE the ability to "sprint" when you wanted a kick...or, would have it, but, the light would just dim as the cells drained...and only be at full brightness on a fresh cell....or, would be regulated to not go over a certain current to have the light just be able to jog...but never run, etc.
:D
The XT11 for example is regulated to maintain brightness even as the cells drain...the circuits suck all the juice they can from the cells to maintain regulation at the required flow rate.
This is one reason better cells work better, as its not just the mAh...its the discharge rate they can support. Cells that can take a higher discharge rate can support more powerful (higher amp draw) lights.
If patrolling/covering an area that takes more than ~ 1/2 hr to cover, and you can see what you need to with ~ 500-600 L, etc...then the use of the single 3100 mAh 18650 works best, and that's how I personally edc the light.
If your use is more like only short bursts of bright max power light, as I use for weapon mounted functions, etc...as in on/acquire the target, and then off and move, etc, or, I am MOSTLY just using low or medium brightness, reading maps, not bumping into stuff, etc...a short run time might not be a problem....as the lower intensities extend run time like crazy.
So, I find it great with a single 18650...that's what works most of the time for me.
I like Callies Kustoms, AW, and Redilast the most, and that's what I mostly have. Xtar and Eagletac, etc, are also good. I look at HJK's reviews mostly to see what the discharge rates, and actual performance are for cells...as I trust our in house resources more than an advertisement for info.
Try to order from a CONUS site rather than waiting on a slow boat from China...I find I don't have the patience for that.
:D
Man TEEJ, thanks for that. It was a very detailed description, but needed for a newbie like me. I guess I should go with the 18650's. I don't need the extra lumens, but the run time would be more important. I will look online for some good 18650's in the 3100mAh range.
You'll need a good charger too, as that's half the equation.
I really like the Xtar WP6 II, as it has 6 bays, and can do RCR123's up to 18650s, and it was highly rated by HJK, etc. Being able to do up to 6 cells at a time is very convenient, especially for me and the number of lighting instruments I go through daily.
:D
Just checked out the charger, looks like it would do the job nicely. I guess I am going to have to buy it lol. Thanks again! Found the battery on the Fenixtactical site, so that's next I guess. :D
TerraLUX makes upgrades for the Stingers which might be more cost efficient.
What about one of ElektroLumens EDC's? Single mode but rough, tough and dependable!
Or the ZebraLight SC600? Not sure of the abuse it could take but the easy access to all modes might be useful.
Peak makes some law enforcement lights as well......
Don't forget to use your CPF discount when ordering!
Barry
Well said, Teej. So there you have it, 600lm on turbo and 500 on high. I was wondering why some people were saying that it's rated at 500lm :confused:
Anyway, congratulations on your purchase! I'm sure you'll love the xt11 as much as everyone who owns one :)
Sent from my GT-S5830 using Tapatalk 2
what is this CPF discount you speak of lol? I bought everything through my local uniform store, so I am not sure if the discounts would be applicable. However, the charger and the battery will be purchased online by me, so if there is a place that accepts a CPF discount, point me there please! :D
I work 3rd shift security at a hospital. I keep a Fenix TK45 on my duty belt. Size of a 2D maglite, uses 8 AA, 4 levels of brightness, two hour run time on turbo (760 lumens).
Sent from my PB99400 using Tapatalk 2
I believe it's BarryG who mentioned the discount. :D
I'm not aware that being a cpf member gives us a discount at certain stores.
Speaking of batteries, I'm currently using AW 2900mah protected 18650s. So far, no problems at all :)
Sent from my iPad using Tapatalk HD
I mentioned madecov here...he has a store called MD-Lightsource, and, there is a decent (10-12% if IIRC) CPF and CPFM discount for members.
