Darwinsdead
Any recommendations and/or assistance is appreciated! :wave:
Does not matter to me, wouldn't mind being able to play before purchasing but if I can't it's no biggie.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
around $250 would be max
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry medium (4-7 inches) or smaller.
5) Emitter/Light source:
LED
6) Manufacturer:
If it's a good light and fits most criteria I have no preference.
7) What battery type do you want to use?
Whatever is best, 123s?
(preferably not a rechargeable light)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
I want maximum throw possible
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
based on maximum output a couple hours would be nice
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box).
Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
I want a forward clicky (Helpful for momentary activation and signaling).
I want a reverse clicky (For use with multi-mode/level lights).
I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
I want a twisty switch (twist head to tighten, and the light will stay on until head is loosened).
I want a tail mounted switch (found on the majority of today’s high end lights).
I want AT LEAST 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
(not a necessity) I want a programmable light.
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (hard anodized) (this is the most common for today’s flashlights).
Stainless steel (durable, but much heavier than aluminum)
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Red filter (for preserving night vision).
3) Format:
LED
6) Manufacturer:
