jhereg
I have been thinking about modding a flashlight to use a 1W or 5W LED. The light I am looking at is one of the "Police" flashlights from ebay. It has a mediocre beam with the incan. bulb, but at least to my untrained eye should be a good flashlight to convert. It is a (2) 123 cell flashlight. The bulb is in a flat (9/16" thick x 3/4" diameter) aluminum holder that threads into the body of the flashlight. It appears the reflector is threaded into the inside of the bezel.
I want my first mod to be relatively easy. Can I direct drive a 1W or 5W LED w/ no other circuitry than a resistor to keep the current within specs? If that is the case I was thinking about putting the LED on the bulb holder as a heat sink & putting the appropriate optics in the bezel. (Assuming they will fit.) Is this a good idea? What would be a better idea? I am also thinking about the rechargeable Pila battery which would replace the 2 123 batteries. Would the same idea work with that battery? Thanks
Andy
Andy
