Re: Wicked Lasers Torch. Help with tailcap.
Jeff, welcome to CPF. I have not seen a WL in person, but Mac's design had a PCB disc that was held in place with a snap-on clip spring. On the outside of the tailcap there was a rubber covering a Judco 10Amp switch. Not sure if that hole is to release a clip or use it to rotate disc which unscrews from an anchor nut underneath.
Thanks for the help! I tried what you describe above and found no clip spring.
However today I managed to get it apart with some brute force. When I say force... I mean FORCE!
Heres what I did in details.
WARNING! LARGE PHOTOS!
So I got it in my mind that I would either fix or break this flashlight. There was no other thing on my mind.
I went searching around for a hex key that fit into the hole that is in the PCB. After about 15 minutes of prying at it the PCB finally popped out. It took a lot of force and the PCB is surprisingly strong!
The spring and PCB are attached to each other with the riveted copper contact. The PCB sits on a aluminum retainer ring that just slides into the cap. Under the retainer ring you can see a aluminum mounting plate for the ground and the tailcap switch. (see photos below)
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3240.jpg
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3242.jpg
Here you can see how the switch and ground are attached.
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3243.jpg
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3250.jpg
These next photos show the switch and ground wire detached from the mount. The ground is only attached by a small screw.
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3251.jpg
Since the flashlight worked fine when I bypassed the tailcap, I knew for sure it was the switch or wiring. I then proceeded to check for shorts. After seeing no sign of a short I then proceeded to take apart the switch.
Here is a photo of the switch's internal components. Pretty simple. There was no sign of any damage anywhere in the tailcap. So After I took apart the switch i stretched the spring a little bit to give it more *click*! :)
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3252.jpg
I then proceeded to make sure all connections were tight and everything was properly connected.
The next photos only show how much damage the tailcap components received after I forced them all back. I must mention. The PCB was JUST as hard to put back as it was to take out. I had to use my body weight and a screwdriver to force it back in. I carefully did so and it worked like a charm.
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3253.jpg
Finished product!
http://i278.photobucket.com/albums/kk98/jeffreythe00/CIMG3254.jpg
Problem?: Well my guess is there was something loose whether that be the switch itself or a component.
Solution: Manpower.
Anyway thanks for reading! :wave:
Jeff
