Flashlight for Son
An eight year old is probably going to use the light mostly for playing. Heck, I am 58 and a lot of what I do with lights is playing. I see that several have recommended the SF G-2. Would you really want to give an eight year old a light that the replacement bulb (P60/P61) will cost you from $16.00 to $23.00? Actually it will cost you more than that when you add shipping. The replacement lamp cost more than half the price of the flashlight. You could go with a Streamlight Scorpion for about $30.00. The Scorpion is a little brighter than the G-2 (P60) and Scorpion bulbs are just $4.50 each. You could also go with the a Brinkmann LX from Wal-Mart for $20.00 and bulbs for it are just $4.50 also. I am not saying the G-2 is not a good light. What I am saying, is that what you want the light for, there are lots of better choices than the G-2 (IMHO). Personally I wouldn't give him a 123 battery light. I would go with something that has a decent run time (over 2 hrs.) and it would use common alkaline batteries.
I have never met a kid that did not like flashlights. Every Friday on my way home from work I pick up my grandson (age 6) and he stays with me until Sunday. We "play" flashlights a lot. We go outside a shine them up in the trees. We go in the back yard and play catch your spot (like tag only with flashlights). We even made up some games to play in the house with them.
James
[ QUOTE ]
James
[/ QUOTE ]
/ubbthreads/images/graemlins/sssh.gif sssshhhhh...
I keep telling my wife why I need these lights.
David <><
That's a good point about lithium batteries.
Re big vs small flashlight: I assume this light is for the kid to play with, not an EDC. A big flashlight is harder to lose, IMO. So I'd still go for a big light. If you want a small light I'd go for a 2aa or 4aa light instead of a lithium. Something like a PT20 could be good. If he makes a habit of draining the batteries by forgetting to turn it off, you can put in rechargeables.
I'm not sure which I would worry about more... Lithium cells or leaking batteries, or exploding flashlights. I have personally had less trouble with lithium cells than any other type I have used.
David <><
The thing that bugged the heck out of me most about flashlights I had as a kid, was flaky switches and battery contacts. I think my flashaholism (the endless quest for better and better flashlights) got started because of that. It still infuriates me that even high class flashaholic lights can have flicker problems.
I think a Princton Tec40 would do well, It runs on 4 AA's and its performance is similar to the SF E2e's. Put in a Mag 3 cell bulb and it performs even better!
-No Lithiums (safety issue)
-Easy to find batteries (cheap too)
-Bulb is ALOT less than a P60
-Cheap (so it's easier to replace)
Good luck!
-Josh
I suggest you to buy him a Streamlight TwinTask-1L.
Because the size is easy to carry, the price is not expensive and it contains two modes(Xenon and LED).
The important thing is that "You can let him know the
different between Xenon and LED"(e.g. brightness,runtime). You can also teach him when will using Xenon mode, when will using LED mode.
