Flashlight with integrated diffuser
saliva_sweet
Hi all. I'm looking for a flashlight that would come with a diffuser to convert to full flood mode. I'd like it to be attached to the light all the time, the back end for example or somewhere inside the case as opposed to a separate diffuser that would probably go missing when needed and be lying around and getting in the way when not needed.
online
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
i'd say $60. Maybe a bit more.
3) Format: flashlight
4) Size: small 3-6 inches
5) Emitter/Light source: LED
6) Manufacturer:
_x___I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
Standard recargeable AA/AAA batteries
Not sure really. I want a standard versatile flashlight. That would be good in a dark room and not be useless outside. Variable output would be nice I guess.
Again, something normal and versatile. Wide throw I guess.
I'll say up to 30m
More is better, but I'd hope for a couple of hours at least.
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Best I can get for the money.
Don't care
Don't care
14)Material/Finish/Coating
Don't care
15) Water resistance
Would love it to work under water.
Integrated diffuser
