Flashlights in games
desert.snake
Eastern Europe
I visited a friend, he decided to play old games ~ 2006-2010, drew attention to the shape of the flashlight beam, very similar to TIR from surefire, especially the uncut old version of the fresnel lens on M3LT/M6LT/UB3T - no spill (could be considered minor), just a fairly wide hotspot. In the game it looks like 100% CRI, it just gives more brightness to the textures without changing the hue of the surfaces. I would like this in reality, with the same beam profile, but not as large size as the SF turboheads
Half-Life 2 and Left4dead
    603 KB
games ignore the tiny fact of scattering, so even if your beam profile is exactly the same as shown above, you would have a lot larger area illuminated by the reflections
the elzetta AVS head has almost the same beam as pictured above, but it doesn't look like this in reality
Elzetta has a pretty good spill and in the center of the hotspot it has a spot of a brighter color, something like an overhotspot. The game is old, if scattering had been implemented, the game would have gone only on supercomputers in those days.
In general, the idea arose, the game has a level editor, it is quite possible to transfer the characteristics of the rays of real lanterns, if not a shade, then a profile for sure. And the actual characteristics of the discharge, and their type of control with brightness levels. And to create something like several traces with different distances and materials, so that you can walk around and see which beam profile is more convenient in any situation.
The beam profile of the weapon light in Left 4 Dead was seemingly designed to enhance jump scares: negligible spill so whenever it illuminates something it comes as a greater surprise. I do appreciate that the game doesn't use the "recharge" mechanic that so many other games utilize - flashlight manages 1-2 minutes on, similar time to recharge - no level in L4D lasts so long that a typical weapon light would exhaust a single set of cells.
This would add considerably more expense to the rendering process. While I'm sure that current generations of hardware are capable of this, it could come at the cost of other areas of detail that the market finds more important.
ooooh so you want to simulate the flashlights in the game, I thought you wanted it the other way around... okhay okhay gotcha.
To be honest it's perfectly doable, you just need a few whitewall shots at different distances and work your way back from there. It will be far from realistic, but can give you a good idea how an extreme thrower ( e.g. Modlite, Malkoff E2HT and so on ) versus a floody beam would look like in different scenarios. If I recall correctly the source engine has some flying particle physics as well, so you could check it out in a dusty environment.
The old Half-Life/Black Mesa beams are my reference for TIR lights. It's very circular and even, but not perfect. And I see your buddy is a fan of the Duct Tape mod as well! The Doom 3 flashlight's beam is a classic, I love the dirty appearance full of artifacts.
Regarding range, it's a matter of scale. I've tried making uber-throwers in mods, and unlike IRL, they take away from the atmosphere. Not to mention, the way a number of implementations are coded, the longer the beam goes for the more geometry it has to account for. This can make the engine chug.
Here's an interesting one, where the creator made three different flashlight beam profiles including CCTs:
