krutzbeuazen
RDZombie,
actually i had a look at those converters, and read through most of the comments. they seem to be quite bad from efficiency, but that wouldnt really matter for violet lasers, and under 50mA needed..
a simple test for them would to connect two LEDs (blue, white, violet, all have 3.3v drop) in series. if they still light up, the circuit outputs high enough voltage. for regular "small" LEDs, 4 pieces should be used, two in series, and those two strings parallel. if they still light up as bright as normal, it should equal 6.6v with 40mA. or better, connect those 4 LEDs, and measure the current with a multimeter between the circuit and the LEDs.
why i write this noobie-testing method?
i dont trust those circuits and my multimeter any more. i put a 100uF capacitor across the output of one circuit, and still measured around 50v. and then that extreme "i lose all current at slightly higher voltage" behavior..
anyway, i am very interested in what you may find out about those circuits!
manuel
manuel
